Einleitung
In this guide, you will learn how to disassemble the broken/damaged screen from the rest of the laptop, allowing you to replace it for a new one. This guide will also teach you what the proper and necessary tools are for this repair.
Werkzeuge
Ersatzteile
With a plastic opening tool, prop the plastic panel up to separate it from the rest of the laptop.
Slowly pull the plastic panel from the entire laptop.
Remove the four 5 mm screws with a Phillips #1 screwdriver, each located at the four corners of the screen.
At this point, the screen should be completely disconnected from the rest of the laptop.
Ein weiterer Nutzer hat diese Anleitung absolviert.
