Einleitung
Replacing the keyboard on your laptop may seem daunting at first, but it is actually a relatively simple component to remove and replace. With the use of a few tools and about fifteen minutes of work, you can have a new keyboard up and running for your laptop.
Was du brauchst
Flip the laptop over. Keep the front end facing away from you, so the battery appears at the top.
While holding the locking mechanism to the right, insert your finger into the tab and lift up.
Remove the 4mm Phillips head screw in the middle of the laptop with a Phillips head #00 screwdriver.
Remove the plastic casing above the keyboard with the plastic opening tool. Start at the edges of the plastic casing and move toward the middle.
Remove the 4mm Phillips head screws at the top of the keyboard at both ends, using the Phillips head #00 screwdriver.
Gently pull the ribbon toward the screen until it slides out of the connecting point.
Remove keyboard.
