Was du brauchst
Slide both latches to the unlocked position to release the battery.
Pull the battery toward you while holding the left latch.
Remove the sixteen screws at the locations shown with the Phillips 00 screwdriver.
Remove the single 4 mm screw holding the port in place with the Phillips 00 screwdriver.
Use the plastic opening tool to disconnect the port from its power source on the laptop. This will be the wire connector with the white connection.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
