Was du brauchst
Slide both latches to the unlocked position to release the battery.
Pull the battery toward you while holding the left latch.
Remove the sixteen screws at the locations shown with the Phillips 00 screwdriver.
Unscrew the two 3.5 mm screws from the Wi-Fi card with the Phillips 00 screwdriver.
Pull the Wi-Fi card towards the battery slot to release it.
Remove the three wires from the Wi-Fi card by pulling them straight up and off.
The Wi-Fi card should now be free of the laptop.
