Zum Hauptinhalt wechseln
Toshiba Portege R500 Wi-FI Card Replacement
Was du brauchst
  1. Toshiba Portege R500 Wi-FI Card Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Portege R500 Wi-FI Card Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make sure the device is off to prevent data loss.
    • Slide both latches to the unlocked position to release the battery.
    • Switch the latch on the right to reveal red. The latch on the left needs to be held.
    • Pull the battery toward you while holding the left latch.
  2. Toshiba Portege R500 Wi-FI Card Replacement, Wi-FI Card: Schritt 2, Bild 1 von 1
    • Remove the sixteen screws at the locations shown with the Phillips 00 screwdriver.
  3. Toshiba Portege R500 Wi-FI Card Replacement: Schritt 3, Bild 1 von 1
    • Pull up on the back casing and remove it, revealing the Wi-Fi card.
  4. Toshiba Portege R500 Wi-FI Card Replacement: Schritt 4, Bild 1 von 2 Toshiba Portege R500 Wi-FI Card Replacement: Schritt 4, Bild 2 von 2
    • Unscrew the two 3.5 mm screws from the Wi-Fi card with the Phillips 00 screwdriver.
    • Pull the Wi-Fi card towards the battery slot to release it.
  5. Toshiba Portege R500 Wi-FI Card Replacement: Schritt 5, Bild 1 von 1
    • Remove the three wires from the Wi-Fi card by pulling them straight up and off.
    • The Wi-Fi card should now be free of the laptop.
    • When removing the wires be sure to remember which wire came from which port, consider marking them so that you can remember.
Abschluss
JRJones
169 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 2-19, Maness Spring 2013 Mitglied von Cal Poly, Team 2-19, Maness Spring 2013
CPSU-MANESS-S13S2G19
3 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 1,277
