Zum Hauptinhalt wechseln
Toshiba Portege R700-S1312 Hard Drive Replacement
Was du brauchst
  1. Toshiba Portege R700-S1312 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Locate the battery on the backside of the laptop. The battery is usually located at the bottom.
  2. Toshiba Portege R700-S1312 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Locate the battery lock button and push it towards the unlock position.
  3. Toshiba Portege R700-S1312 Hard Drive Replacement: Schritt 3, Bild 1 von 3 Toshiba Portege R700-S1312 Hard Drive Replacement: Schritt 3, Bild 2 von 3 Toshiba Portege R700-S1312 Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Hold the next lock in the unlock position. Simultaneously pull the battery towards you.
  4. Toshiba Portege R700-S1312 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 1
    • Remove the 40 mm screws from the RAM cover using a Phillips #00 Screwdriver.
  5. Toshiba Portege R700-S1312 Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Lift and remove the RAM cover to reveal the first of 2 40mm screws holding down the hard drive cover. Remove the screw using a Phillips #00 Screwdriver.
  6. Toshiba Portege R700-S1312 Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Remove the second 40mm hard drive cover screw using a Phillips #00 Screwdriver.
  7. Toshiba Portege R700-S1312 Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Lift and remove the hard drive cover.
  8. Toshiba Portege R700-S1312 Hard Drive Replacement: Schritt 8, Bild 1 von 1
    • Connect the drive (in this case a solid state drive) to the laptop using the SATA cable located inside the hard drive placement area.
  9. Toshiba Portege R700-S1312 Hard Drive Replacement: Schritt 9, Bild 1 von 1
    • Once the drive is connected, carefully insert the drive into the laptop enclosure.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 23
Insgesamt: 2,494
