Einleitung
This guide will help Toshiba users replace or add RAM to their laptop devices.
Was du brauchst
Locate the battery on the backside of the laptop. The battery is usually located at the bottom.
Hold the next lock in the unlock position. Simultaneously pull the battery towards you.
Using a Phillips #00 Screwdriver unscrew the 2 40mm screws that are located on the plate covering the RAM.
Fast fertig!
To reassemble your device, simply follow steps 1-3 in reverse order.
Abschluss
