Zum Hauptinhalt wechseln
Toshiba Portege R700-S1312 RAM Replacement
Was du brauchst
  1. Toshiba Portege R700-S1312 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Locate the battery on the backside of the laptop. The battery is usually located at the bottom.
  2. Toshiba Portege R700-S1312 RAM Replacement: Schritt 2, Bild 1 von 1
    • Locate the battery lock button and push it towards the unlock position.
  3. Toshiba Portege R700-S1312 RAM Replacement: Schritt 3, Bild 1 von 3 Toshiba Portege R700-S1312 RAM Replacement: Schritt 3, Bild 2 von 3 Toshiba Portege R700-S1312 RAM Replacement: Schritt 3, Bild 3 von 3
    • Hold the next lock in the unlock position. Simultaneously pull the battery towards you.
  4. Toshiba Portege R700-S1312 RAM Replacement, RAM: Schritt 4, Bild 1 von 1
    • Flip the laptop over.
  5. Toshiba Portege R700-S1312 RAM Replacement: Schritt 5, Bild 1 von 1
    • Using a Phillips #00 Screwdriver unscrew the 2 40mm screws that are located on the plate covering the RAM.
  6. Toshiba Portege R700-S1312 RAM Replacement: Schritt 6, Bild 1 von 1
    • Remove the plate covering the RAM.
  7. Toshiba Portege R700-S1312 RAM Replacement: Schritt 7, Bild 1 von 1
    • Pull the sides holding the RAM in place until there is a slight pop.
  8. Toshiba Portege R700-S1312 RAM Replacement: Schritt 8, Bild 1 von 1
    • The RAM stick will lift up on its own. Simply remove it.
  9. Toshiba Portege R700-S1312 RAM Replacement: Schritt 9, Bild 1 von 1
    • Place new RAM into the RAM drive and gently press until there is a slight pop.
Abschluss
To reassemble your device, simply follow steps 1-3 in reverse order.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 505
