Einleitung
This guide will show you how to replace the back plate on a Toshiba Portege R705-P35 laptop. This is a prerequisite guide to replace internal components like the fan, DVD drive and Wi-Fi card. It is necessary to remove all the back plate screws; be sure to separate the different sizes of screws for easy reinstallation.
Was du brauchst
Turn off and unplug the laptop.
Place the laptop upside-side-down with the hinges towards you.
Use your right hand to move the right switch from the locked position to the unlocked position.
Use your left hand to move the left switch from the locked position to the unlocked position.
While keeping the left switch unlocked, pull the battery away from the computer with your right hand.
Loosen the two captive screws in the plate with a Phillips #00 screwdriver.
Remove the plate from the laptop.
Loosen the two captive screws in the hard drive plate using a Phillips #00 screwdriver.
Remove the two 13 mm screws from the back plate using a Phillips #0 screwdriver.
Remove the thirteen 6 mm screws from the back plate using a Phillips #00 screwdriver.
Remove the five 5 mm screws from the back plate using a Phillips #00 screwdriver.
Pull the back plate off, starting from the right side, being cautious of the ports on the left side.
