Einleitung
The Toshiba Portege R705-P35 has a DVD disc drive to load and play video files. If your DVD won't play, even after cleaning, the DVD drive may need to be replaced using this guide. The drive is located on the left side of the device when it is open and in the standard position. The drive can be easily accessed by removing the back panel. Be sure to save all the screws and the metal plate for easy reinstallation. Also when plugging in the ribbon cable, make sure it's completely inserted.
Was du brauchst
Turn off and unplug the laptop.
Place the laptop upside-side-down with the hinges towards you.
Use your right hand to move the right switch from the locked position to the unlocked position.
Use your left hand to move the left switch from the locked position to the unlocked position.
While keeping the left switch unlocked, pull the battery away from the computer with your right hand.
Loosen the two captive screws in the plate with a Phillips #00 screwdriver.
Remove the plate from the laptop.
Loosen the two captive screws in the hard drive plate using a Phillips #00 screwdriver.
Remove the two 13 mm screws from the back plate using a Phillips #0 screwdriver.
Remove the thirteen 6 mm screws from the back plate using a Phillips #00 screwdriver.
Remove the five 5 mm screws from the back plate using a Phillips #00 screwdriver.
Pull the back plate off, starting from the right side, being cautious of the ports on the left side.
Use an opening tool to detach the hard drive connector from the DVD drive.
Remove the two 4 mm screws using a Phillips #00 screwdriver.
Remove the one 3 mm screw using a Phillips #00 screwdriver.
Remove the silver bracket that comes loose.
Pull on the orange bar with your fingers to detach it from the DVD drive.
Pull out and remove the DVD drive from the laptop.
