Zum Hauptinhalt wechseln
Toshiba Portege R705-P35 RAM Replacement
Was du brauchst
  1. Toshiba Portege R705-P35 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off and unplug the laptop.
    • Failure to turn off and unplug the cable could result in electric shock.
    • Place the laptop upside-side-down with the hinges towards you.
  2. Toshiba Portege R705-P35 RAM Replacement: Schritt 2, Bild 1 von 1
    • Use your right hand to move the right switch from the locked position to the unlocked position.
    • Use your left hand to move the left switch from the locked position to the unlocked position.
  3. Toshiba Portege R705-P35 RAM Replacement: Schritt 3, Bild 1 von 2 Toshiba Portege R705-P35 RAM Replacement: Schritt 3, Bild 2 von 2
    • While keeping the left switch unlocked, pull the battery away from the computer with your right hand.
  4. Toshiba Portege R705-P35 RAM Replacement, RAM Plate: Schritt 4, Bild 1 von 3 Toshiba Portege R705-P35 RAM Replacement, RAM Plate: Schritt 4, Bild 2 von 3 Toshiba Portege R705-P35 RAM Replacement, RAM Plate: Schritt 4, Bild 3 von 3
    • Loosen the two captive screws in the plate with a Phillips #00 screwdriver.
    • Remove the plate from the laptop.
  5. Toshiba Portege R705-P35 RAM Replacement, RAM: Schritt 5, Bild 1 von 2 Toshiba Portege R705-P35 RAM Replacement, RAM: Schritt 5, Bild 2 von 2
    • Using a spudger or your fingers, push one of the metal rods on either side of the RAM stick away from it until you hear a light clicking noise.
    • Repeat this procedure with the other metal rod on the opposite side of the RAM stick.
  6. Toshiba Portege R705-P35 RAM Replacement: Schritt 6, Bild 1 von 2 Toshiba Portege R705-P35 RAM Replacement: Schritt 6, Bild 2 von 2
    • Once the RAM stick pops out to an angle, pull it outward.
Abschluss
UMass Dartmouth, Team 1-4, Botvin Spring 2022 Mitglied von UMass Dartmouth, Team 1-4, Botvin Spring 2022
UMASSD-BOTVIN-S22S1G4
3 Mitglieder
24 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 11
Insgesamt: 140
