Einleitung
With this guide, you will be able to replace the HDMI port on the Toshiba Portege R835-P56X. Before you begin this process, refer back to the Battery Replacement Guide in order to take out the battery.
Was du brauchst
Use the screwdriver to unscrew 18 screws.
Place them to the side for the reassembly process.
Remove the fan by unscrewing the screws with the screwdriver
Place the screws aside for reassembly process.
Locate the HDMI port.
Unscrew the screws using the screwdriver.
Pull the HDMI port off by gently holding the orange band and pulling the HDMI port at the same time.
Eine weitere Person hat diese Anleitung absolviert.
