Zum Hauptinhalt wechseln
Toshiba Portege R835-P56X Screen Replacement
Was du brauchst
  1. Toshiba Portege R835-P56X Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place the laptop with the battery facing up.
    • Make sure the laptop is powered off and unplugged.
  2. Toshiba Portege R835-P56X Screen Replacement: Schritt 2, Bild 1 von 2 Toshiba Portege R835-P56X Screen Replacement: Schritt 2, Bild 2 von 2
    • Unlock the clips by pulling towards the open lock.
  3. Toshiba Portege R835-P56X Screen Replacement: Schritt 3, Bild 1 von 3 Toshiba Portege R835-P56X Screen Replacement: Schritt 3, Bild 2 von 3 Toshiba Portege R835-P56X Screen Replacement: Schritt 3, Bild 3 von 3
    • Hold the unlock clip while pulling the battery away from the laptop.
  4. Toshiba Portege R835-P56X Screen Replacement, Screen: Schritt 4, Bild 1 von 3 Toshiba Portege R835-P56X Screen Replacement, Screen: Schritt 4, Bild 2 von 3 Toshiba Portege R835-P56X Screen Replacement, Screen: Schritt 4, Bild 3 von 3
    • Use the screwdriver to unscrew 18 screws.
    • Remove the back cover of the laptop.
  5. Toshiba Portege R835-P56X Screen Replacement: Schritt 5, Bild 1 von 1
    • Remove the screw from the metal hinges in the top corners of the laptop as shown in the picture.
  6. Toshiba Portege R835-P56X Screen Replacement: Schritt 6, Bild 1 von 1
    • Disconnect the white plug with red and black wires located on the right-most upper corner with the chrome hinges pointed farthest away from you.
  7. Toshiba Portege R835-P56X Screen Replacement: Schritt 7, Bild 1 von 2 Toshiba Portege R835-P56X Screen Replacement: Schritt 7, Bild 2 von 2
    • Remove the chrome hinges using the blue prying tool. The hinges should pop right off without must effort.
  8. Toshiba Portege R835-P56X Screen Replacement: Schritt 8, Bild 1 von 1
    • Remove the screws located underneath the hinges.
  9. Toshiba Portege R835-P56X Screen Replacement: Schritt 9, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using tweezers, remove the plastic caps from the top edge of the laptop screen, located near the front-facing camera. All but the cap closest to the camera should be removed.
  10. Toshiba Portege R835-P56X Screen Replacement: Schritt 10, Bild 1 von 1
    • Remove the screws located underneath the plastic caps.
  11. Toshiba Portege R835-P56X Screen Replacement: Schritt 11, Bild 1 von 1
    • Snap the laptop screen casing off.
  12. Toshiba Portege R835-P56X Screen Replacement: Schritt 12, Bild 1 von 2 Toshiba Portege R835-P56X Screen Replacement: Schritt 12, Bild 2 von 2
    • Disconnect the grey mesh wire from underneath the unattached laptop screen.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Anay Sanchez
494 Reputation
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 604
