Einleitung
In this guide we will remove the screen from a Toshiba Portege R835-P56X
Was du brauchst
Use the screwdriver to unscrew 18 screws.
Remove the back cover of the laptop.
Remove the screw from the metal hinges in the top corners of the laptop as shown in the picture.
Disconnect the white plug with red and black wires located on the right-most upper corner with the chrome hinges pointed farthest away from you.
Remove the chrome hinges using the blue prying tool. The hinges should pop right off without must effort.
Using tweezers, remove the plastic caps from the top edge of the laptop screen, located near the front-facing camera. All but the cap closest to the camera should be removed.
Eine weitere Person hat diese Anleitung absolviert.
