Einleitung
This guide will teach you how to replace the battery of the Toshiba Portege Z835-P330.
Was du brauchst
Remove the thirteen 1.4mm screws on back of device using a Phillips #2 screwdriver.
Locate hidden screw found in the middle of back hardcover.
Remove the single Torx Security screw using a TR7 screwdriver.
Remove the white plug connected to the battery by gently pulling it out of the socket.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
6 Kommentare
These steps also work for the Z935-P300. NOTE: the center screw in step two is a Torx Security TR7.
Will it lose it’s memory when the power and battery are disconnected? Do I need to back it up before I do this? My battery is so dead that the laptop shuts down after just a few minutes without the ac cord plugged in.
Thank you!
I suspect you have already completed your repair and now know the answer, however, in the event that you are still waiting on a response. The short answer is no, the storage drive will not loose data when changing the battery. Despite this, it is always wise to have a backup.
Could anyone please tell me which type of screws are these ?
Which screws are you referring to? I believe they all have their details size and type listed above. Is there one in particular you need further detail on?
