Zum Hauptinhalt wechseln
Toshiba Portege Z835-P330 Solid-State Drive Replacement
Was du brauchst
  1. Toshiba Portege Z835-P330 Solid-State Drive Replacement, Solid-State Drive: Schritt 1, Bild 1 von 1
    • Remove the thirteen 1.4mm screws using a Phillips #2 screwdriver.
  2. Toshiba Portege Z835-P330 Solid-State Drive Replacement: Schritt 2, Bild 1 von 1
    • Locate hidden screw found in the middle of back hardcover.
    • Found under rubber covering shown in picture.
    • Remove the single Torx Security screw using a TR7 screwdriver.
  3. Toshiba Portege Z835-P330 Solid-State Drive Replacement: Schritt 3, Bild 1 von 1
    • Peel off hard cover to expose interior of device.
  4. Toshiba Portege Z835-P330 Solid-State Drive Replacement: Schritt 4, Bild 1 von 1
    • Find the solid-state drive located below the battery, and next to the RAM.
    • Unscrew the two 1mm screws located at the top of the solid-state drive with a Phillips #1 screwdriver.
  5. Toshiba Portege Z835-P330 Solid-State Drive Replacement: Schritt 5, Bild 1 von 1
    • Pull the solid-state drive from its socket
    • The solid-state drive should automatically pop-up from its housing once the screws are removed.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 1,205
