Einleitung
If your computer is running slow or becomes cold this can be due to a faulty RAM or you not having enough RAM in the computer. Use this guide to remove and replace your RAM.
Was du brauchst
Use a Phillips #0 screwdriver to unscrew the single 8 mm screw and remove the RAM cover.
Using the iFixit opening tools, press on the two metal pieces holding the RAM cartridge in place. Do this for both RAM cards.
Eine weitere Person hat diese Anleitung absolviert.
