Einleitung
If your computer is running slow or becomes cold this can be due to a faulty RAM or you not having enough RAM in the computer. Use this guide to remove and replace your RAM.
Was du brauchst
Use a Phillips #0 screwdriver to unscrew the single 8 mm screw and remove the RAM cover.
Using the iFixit opening tools, press on the two metal pieces holding the RAM cartridge in place. Do this for both RAM cards.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
