Einleitung
If you need to get to the Hard Disk Drive or need to remove the CD drive, use this guide.
Was du brauchst
Hold the switch on the left and pull the battery up towards you, using the marked tab, to take it out.
Use a JIS #0 screwdriver to unscrew the two 4.6 mm screws at the base of the casing.
Pull off the part of the case that's now loose by the indicated tab.
Fast fertig!
Abschluss
