Einleitung
If your keys aren’t working, then use this guide to help you replace the keyboard.
Was du brauchst
Hold the switch on the left and pull the battery up towards you, using the marked tab, to take it out.
Locate the plastic bar at the top of the keyboard.
Wedge a plastic opening tool under the bar and pop the bar out.
Lift the keyboard to get to the plastic ribbon underneath.
Using the Spudger, press a small tab on the left side of the ribbon. Then pull the ribbon out from the casing.
3 weitere Personen haben diese Anleitung absolviert.
