Einleitung
If your laptop is booting to the BIOS screen and it is not because of a faulty hard disk drive, then use this guide to replace the RAM sticks.
Was du brauchst
Hold the switch on the left and pull the battery up towards you, using the marked tab, to take it out.
Use a JIS #0 screwdriver to remove the three 4.8mm long screws that secure the RAM cover.
Lift the cover off using the indent for leverage.
Use a spudger or your fingers to push the RAM brackets outwards until the RAM pops up.
Once the RAM stick is angled up, pull it out along the angle.
