Was du brauchst
Identify the two sliding locks on either side of the battery.
Simultaneously slide both locks outward to release the battery.
Locate the optical drive retaining screw on the underside of the laptop.
Using your finger or a spudger, push the optical drive out of its compartment so you can grab it.
Pull the optical drive out of its slot in the side of the laptop.
Loosen the single screw on the service panel by twisting counterclockwise with a Phillips #00 screwdriver.
Using your fingers, pull the retaining clips away from the RAM sticks.
Pull the RAM sticks out of the slots.
Using a Phillips #00 screwdriver, remove all the remaining fourteen screws from the bottom case of the laptop.
Using a Phillips #00 screwdriver, remove the five screws under the service panel.
Remove the retaining clip.
Disconnect the two ribbon cables connecting the keyboard to the laptop.
Unplug the connector on the bottom of the laptop.
Using a Phillips #00 screwdriver, remove the four screws securing the fan assembly to the laptop.
Using a Phillips #00 screwdriver, remove the four screws securing the motherboard to the laptop.
