Zum Hauptinhalt wechseln
Toshiba Qosmio X775-3DV80 Wifi Chip Replacement
Was du brauchst
  1. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn your laptop over so the underside is facing up.
  2. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: Schritt 2, Bild 1 von 2 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: Schritt 2, Bild 2 von 2
    • Identify the two sliding locks on either side of the battery.
    • Simultaneously slide both locks outward to release the battery.
  3. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: Schritt 3, Bild 1 von 1
    • Pull the battery straight out of its slot to remove it.
  4. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement, Optical Drive: Schritt 4, Bild 1 von 1
    • Locate the optical drive retaining screw on the underside of the laptop.
  5. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: Schritt 5, Bild 1 von 1
    • Using a Phillips #00 screwdriver, remove the optical drive retaining screw.
  6. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: Schritt 6, Bild 1 von 2 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: Schritt 6, Bild 2 von 2
    • Using your finger or a spudger, push the optical drive out of its compartment so you can grab it.
    • Pull the optical drive out of its slot in the side of the laptop.
  7. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement, RAM: Schritt 7, Bild 1 von 1
    • Loosen the single screw on the service panel by twisting counterclockwise with a Phillips #00 screwdriver.
    • It is a captive screw that will remain attached to the service panel.
  8. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: Schritt 8, Bild 1 von 1
    • Using a spudger or plastic opening tool, pry off the service panel.
  9. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: Schritt 9, Bild 1 von 3 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: Schritt 9, Bild 2 von 3 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: Schritt 9, Bild 3 von 3
    • Using your fingers, pull the retaining clips away from the RAM sticks.
    • Pull the RAM sticks out of the slots.
  10. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement, Keyboard: Schritt 10, Bild 1 von 2 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement, Keyboard: Schritt 10, Bild 2 von 2
    • Using a Phillips #00 screwdriver, remove all the remaining fourteen screws from the bottom case of the laptop.
    • The service panel should already be removed.
  11. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: Schritt 11, Bild 1 von 2 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: Schritt 11, Bild 2 von 2
    • Using a Phillips #00 screwdriver, remove the five screws under the service panel.
    • Remove the retaining clip.
  12. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: Schritt 12, Bild 1 von 1
    • Using a spudger, pry the keyboard from the top panel of the laptop.
    • Make sure to pry it off all around.
  13. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: Schritt 13, Bild 1 von 3 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: Schritt 13, Bild 2 von 3 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: Schritt 13, Bild 3 von 3
    • Disconnect the two ribbon cables connecting the keyboard to the laptop.
    • Unplug the connector on the bottom of the laptop.
  14. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement, Fan: Schritt 14, Bild 1 von 1
    • Separate the two halves of the base of the laptop.
  15. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: Schritt 15, Bild 1 von 2 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: Schritt 15, Bild 2 von 2
    • Disconnect the two cables.
  16. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: Schritt 16, Bild 1 von 1
    • Remove the palmrest assembly.
  17. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: Schritt 17, Bild 1 von 2 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: Schritt 17, Bild 2 von 2
    • Using a Phillips #00 screwdriver, remove the four screws securing the fan assembly to the laptop.
  18. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: Schritt 18, Bild 1 von 2 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: Schritt 18, Bild 2 von 2
    • Unplug the fan-motherboard connector.
    • Remove the fan unit.
  19. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement, Wifi Chip: Schritt 19, Bild 1 von 1
    • Detach the two coaxial connections from the wifi chip.
  20. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: Schritt 20, Bild 1 von 2 Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: Schritt 20, Bild 2 von 2
    • Using a Phillips #00 screwdriver, remove the two screws from the wifi chip.
  21. Toshiba Qosmio X775-3DV80 Wifi Chip Replacement: Schritt 21, Bild 1 von 1
    • Remove the wifi chip by pulling it out of the PCIe slot.
Abschluss
Jesse Adam Ory
745 Reputation
7 Anleitungen geschrieben
UMass Dartmouth, Team S2-G1, Bailey Spring 2019 Mitglied von UMass Dartmouth, Team S2-G1, Bailey Spring 2019
UMASSD-BAILEY-S19S2G1
4 Mitglieder
21 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 578
