Einleitung
This guide gives instructions on how to remove the disc drive of the Toshiba SD-K740 DVD player.
Was du brauchst
Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
Turn the DVD player on its side.
Remove the 7.7 mm screw.
Flip the DVD player onto its other side.
Flip the DVD player over onto its front face.
Remove the back panel by lifting up and pulling it towards yourself.
Lift and push away the two tabs located in the middle of the player.
Remove the first of three ribbon cables on left hand side of disc drive by pulling vertically.
Remove the second of three ribbon cables on left hand side of disc drive by pulling vertically.
Remove the third of three ribbon cables on left hand side of disc drive by pulling vertically.
Remove the four screws holding the disc drive in place using a #0 Phillips screwdriver.
Eine weitere Person hat diese Anleitung absolviert.
