Einleitung
This guide gives instructions on how to remove the front panel of the Toshiba SD-K740 DVD player, a necessary step to access all parts for repair/replacement.
Was du brauchst
Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
Turn the DVD player on its side.
Remove the 7.7 mm screw.
Flip the DVD player onto its other side.
Flip the DVD player over onto its front face.
Remove the back panel by lifting up and pulling it towards yourself.
Lift and push away the two tabs located in the middle of the player.
