Einleitung
This guide gives instructions on how to remove the Right-Side Motherboard (Yellow) of the Toshiba SD-K740 DVD player, which controls the buttons and power function.
Was du brauchst
Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
Turn the DVD player on its side.
Remove the 7.7 mm screw.
Flip the DVD player onto its other side.
Flip the DVD player over onto its front face.
Remove the back panel by lifting up and pulling it towards yourself.
Lift and push away the two tabs located in the middle of the player.
Remove the black tie holding the two rear ribbon cables together by untwisting it.
Remove the first of two ribbon cables connected to the motherboard by pulling vertically.
Remove the second of two ribbon cables connected to the motherboard by pulling vertically.
Remove the three .303 inch screws attaching the inverter board to the casing using a #0 Phillips screwdriver.
Push the inverter board forward and to the left to remove from the holding ledges.
Lift the inverter board from the back end and pull toward you to complete removal.
