Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
An optical drive allows your computer to read and write to media such as CDs and DVDs. Upgrading or replacing your drive may be necessary to get the most out of your laptop.
  1. The battery is located on the front right corner of the laptop.
    • The battery is located on the front right corner of the laptop.
  2. With one finger on the raised grip, slide the latch towards the front of the laptop.
    • With one finger on the raised grip, slide the latch towards the front of the laptop.
  3. Pull the battery out towards the side. Pull the battery out towards the side.
    • Pull the battery out towards the side.
  4. Lift the battery straight up, out of the computer. Lift the battery straight up, out of the computer.
    • Lift the battery straight up, out of the computer.
  5. Using a set of case opening tools, pry open the left and right sides of the black plastic strip above the keyboard. Fully detach the strip. Fully detach the strip.
    • Using a set of case opening tools, pry open the left and right sides of the black plastic strip above the keyboard.
    • Fully detach the strip.
  6. Unscrew the two screws near the top of the keyboard. Unscrew the two screws near the top of the keyboard.
    • Unscrew the two screws near the top of the keyboard.
  7. Lift the keyboard by holding the middle top of the keyboard. The keyboard is still connected by a ribbon cable to the motherboard.
    • Lift the keyboard by holding the middle top of the keyboard.
    • The keyboard is still connected by a ribbon cable to the motherboard.
  8. Carefully pull upwards on the ribbon cable to detach. Remove keyboard. Remove keyboard.
    • Carefully pull upwards on the ribbon cable to detach.
    • Remove keyboard.
  9. Unscrew the screw located on the left side of the optical drive near the heat sink cover in the middle of the laptop.
    • Unscrew the screw located on the left side of the optical drive near the heat sink cover in the middle of the laptop.
  10. Using spudger, push the optical drive out to the right. Using spudger, push the optical drive out to the right. Using spudger, push the optical drive out to the right.
    • Using spudger, push the optical drive out to the right.
Abschluss
Kiril Lange
943 Reputation
9 Anleitungen geschrieben
USF Tampa, Team 3-2, Brown Fall 2014 Mitglied von USF Tampa, Team 3-2, Brown Fall 2014
USFT-BROWN-F14S3G2
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 95
