Zum Hauptinhalt wechseln
Einleitung
Prerequisite Only
Ersatzteile
Keine Ersatzteile angegeben.
  1. Disconnect both speaker connectors located near the center of the laptop. Disconnect both speaker connectors located near the center of the laptop.
    • Disconnect both speaker connectors located near the center of the laptop.
  2. Unscrew all visible screws on the heat sink shield. Unscrew all visible screws on the heat sink shield.
    • Unscrew all visible screws on the heat sink shield.
  3. Disconnect the monitor connector. Disconnect the monitor connector.
    • Disconnect the monitor connector.
  4. Starting from the front right corner pry apart the black bottom from the gray top. Starting from the front right corner pry apart the black bottom from the gray top. Starting from the front right corner pry apart the black bottom from the gray top.
    • Starting from the front right corner pry apart the black bottom from the gray top.
  5. Set aside the top half. Set aside the top half.
    • Set aside the top half.
Abschluss
Kiril Lange
943 Reputation
9 Anleitungen geschrieben
USF Tampa, Team 3-2, Brown Fall 2014 Mitglied von USF Tampa, Team 3-2, Brown Fall 2014
USFT-BROWN-F14S3G2
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 32
