Einleitung
For the individual who constantly needs to run lots of programs at once, RAM that comes with a laptop often isn't enough. This guide shows you how to replace RAM that is either too small or gone bad.
Was du brauchst
Using a Phillips screwdriver, unscrew and remove two screws labeled F4 from the plastic piece on the back of the laptop with the RAM indicator.
Using a flathead screwdriver or a shiv, insert the flathead of the screwdriver in the space between the plastic piece and the rest of the laptop. Pry the plastic piece off by moving the flathead screwdriver up and down.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
