Zum Hauptinhalt wechseln
Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement
Was du brauchst
  1. Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement, Battery: Schritt 1, Bild 2 von 2
    • To prevent electrical shock, make sure the computer is turned off; and disconnect the power adapter from the computer and electrical outlet prior to beginning any repairs on this device.
    • Turn the laptop upside down with the battery facing you.
  2. Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: Schritt 2, Bild 1 von 3 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: Schritt 2, Bild 2 von 3 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: Schritt 2, Bild 3 von 3
    • Slide both the left and right battery release tabs outwards away from center of the laptop.
    • Right release tab will remain locked in place.
    • While still holding the left release tab, slide the battery towards you using your right hand.
    • Fully remove the battery from the laptop.
  3. Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement, Optical Disk Drive (DVD/CD-ROM): Schritt 3, Bild 1 von 2 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement, Optical Disk Drive (DVD/CD-ROM): Schritt 3, Bild 2 von 2
    • Turn the laptop around with the battery slot facing away from you.
    • Remove the 5.0 mm screw that is holding the optical disk drive internally in place using the Phillips #1 screwdriver.
  4. Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: Schritt 4, Bild 1 von 3 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: Schritt 4, Bild 2 von 3 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: Schritt 4, Bild 3 von 3
    • Turn the laptop back over (cover-side up) with the optical disk drive on the right side.
    • With the plastic opening tool, pry the drive out from the top.
    • Using the opening tool, pull the drive out of the drive bay.
Abschluss
To reassemble your device after replacing the DVD SuperMulti drive, follow these instructions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team S2-G1, Isaacson Spring 2017 Mitglied von UMass Dartmouth, Team S2-G1, Isaacson Spring 2017
UMASSD-ISAACSON-S17S2G1
4 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 18
Insgesamt: 596
