Einleitung
This guide will help you replace Toshiba Satellite A105-S4284 RAM. RAM allows memory to be accessed directly in a random order. You might need to replace a RAM if your computer shuts down abruptly, your computer performance is low quality, or the computer fails to install new programs.
Werkzeuge
Ersatzteile
Turn your laptop upside down, and slide the right release tab outward.
Using you left hand, hold the left release tab towards the left side and then pull the battery out.
Loosen the screw located on the cover of the RAM using Phillips #1 screwdriver.
With your fingers, carefully remove the middle panel by lifting the edge with the indent.
Using your fingers, release the tabs on both ends of the RAM.
Pull the RAM out.
Ein weiterer Nutzer hat diese Anleitung absolviert.
Ein Kommentar
how to remove a bios passcode off of a Toshiba Satellite a105 s4374 laptop
