Zum Hauptinhalt wechseln
Toshiba Satellite A205-S4577 RAM Replacement
Was du brauchst
  1. Toshiba Satellite A205-S4577 RAM Replacement, RAM: Schritt 1, Bild 1 von 1
    • Identify the rectangular plastic RAM cover located in the bottom part of your laptop.
    • Remove the 4mm flat-head screws on the RAM cover.
    • Use a plastic opening tool to pry the RAM cover upward.
  2. Toshiba Satellite A205-S4577 RAM Replacement: Schritt 2, Bild 1 von 1
    • Remove the RAM cover.
  3. Toshiba Satellite A205-S4577 RAM Replacement: Schritt 3, Bild 1 von 1
    • Press the two tabs on the side of the PC2-5300 2 GB RAM Chip to unlatch it.
    • To remove the PC2-5300 2 GB RAM Chip, pull it out at a slightly upward angle.
  4. Toshiba Satellite A205-S4577 RAM Replacement: Schritt 4, Bild 1 von 2 Toshiba Satellite A205-S4577 RAM Replacement: Schritt 4, Bild 2 von 2
    • To replace the ram, insert the new PC2-5300 1 GB RAM Chip you have gathered back into the laptop.
    • Make sure the notch in the middle of the stick is lined up correctly and push firmly into place.
    • Once pushed firmly into place, firmly push down and latch the RAM sticks to the laptop. Repeat process for additional RAM sticks.
  5. Toshiba Satellite A205-S4577 RAM Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite A205-S4577 RAM Replacement: Schritt 5, Bild 2 von 2
    • To replace the ram, insert the new RAM sticks you have back into the computer.
    • Once pushed firmly into place, firmly push down and latch the RAM sticks to the computer. Repeat process for additional RAM sticks.
  6. Toshiba Satellite A205-S4577 RAM Replacement: Schritt 6, Bild 1 von 1
    • Screw the back plate of the RAM back onto the device.
Ziellinie
Daniel Johnson
108 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 17-6, Regan Spring 2013 Mitglied von Cal Poly, Team 17-6, Regan Spring 2013
CPSU-REGAN-S13S17G6
5 Mitglieder
33 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 1,416
