Zum Hauptinhalt wechseln
Toshiba Satellite A205-S5812 Battery Replacement
  1. Toshiba Satellite A205-S5812 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off your laptop before beginning.
    • Turn the laptop over so the base of the laptop faces the ceiling.
  2. Toshiba Satellite A205-S5812 Battery Replacement: Schritt 2, Bild 1 von 1
    • Push the two plastic tabs retaining the battery into the chassis to each respective side. This will push the battery up slightly and release it from the bottom of the notebook.
  3. Toshiba Satellite A205-S5812 Battery Replacement: Schritt 3, Bild 1 von 1
    • Using a finger or small prying device, pull the battery upwards from the recessed area. Then, simply pull the battery out of the notebook and gently set it aside.
Abschluss
To replace the battery on your device, follow these instructions in reverse order.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 280
