Zum Hauptinhalt wechseln
Toshiba Satellite A215 S4697 Optical Drive Replacement
Was du brauchst
  1. Toshiba Satellite A215 S4697 Optical Drive Replacement, Battery: Schritt 1, Bild 1 von 3 Toshiba Satellite A215 S4697 Optical Drive Replacement, Battery: Schritt 1, Bild 2 von 3 Toshiba Satellite A215 S4697 Optical Drive Replacement, Battery: Schritt 1, Bild 3 von 3
    • Close the laptop and turn it over so that the base is facing upwards and the spine is facing away from you.
    • Find the battery compartment.
    • Slide the left slider which is just beneath the battery compartment into its leftmost position.
  2. Toshiba Satellite A215 S4697 Optical Drive Replacement: Schritt 2, Bild 1 von 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: Schritt 2, Bild 2 von 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: Schritt 2, Bild 3 von 3
    • Slide and hold the right slider into its rightmost position. Lift the battery out of the compartment.
    • Do not touch the gold nodes inside the compartment.
  3. Toshiba Satellite A215 S4697 Optical Drive Replacement, Optical Drive: Schritt 3, Bild 1 von 3 Toshiba Satellite A215 S4697 Optical Drive Replacement, Optical Drive: Schritt 3, Bild 2 von 3 Toshiba Satellite A215 S4697 Optical Drive Replacement, Optical Drive: Schritt 3, Bild 3 von 3
    • Turn computer over so that the battery compartment is facing up and is at the top.
    • Locate and unscrew one captive Phillips #1 screw located at the center.
    • A captive screw cannot be completely removed from the device's component.
  4. Toshiba Satellite A215 S4697 Optical Drive Replacement: Schritt 4, Bild 1 von 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: Schritt 4, Bild 2 von 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: Schritt 4, Bild 3 von 3
    • Use a plastic opening tool to open the motherboard access cover.
    • Do not touch the motherboard.
  5. Toshiba Satellite A215 S4697 Optical Drive Replacement: Schritt 5, Bild 1 von 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: Schritt 5, Bild 2 von 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: Schritt 5, Bild 3 von 3
    • Remove one 1.5mm Phillips #1 screw located near the top left edge of the opening.
  6. Toshiba Satellite A215 S4697 Optical Drive Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite A215 S4697 Optical Drive Replacement: Schritt 6, Bild 2 von 2
    • Flip your device right side up, and rotate it so that the optical drive is facing you.
    • Insert a paper clip into a manual release switch located to the right of the automatic release button.
    • Optical Drive will not release if you insert the clip diagonally. Make sure to insert the clip straight into the switch.
  7. Toshiba Satellite A215 S4697 Optical Drive Replacement: Schritt 7, Bild 1 von 2 Toshiba Satellite A215 S4697 Optical Drive Replacement: Schritt 7, Bild 2 von 2
    • Gently pull out the disk drive until you can see the metallic case of the optical drive.
    • Hold the metal case and continue to pull the drive out toward you.
  8. Toshiba Satellite A215 S4697 Optical Drive Replacement: Schritt 8, Bild 1 von 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: Schritt 8, Bild 2 von 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: Schritt 8, Bild 3 von 3
    • Once you see the yellow labels on the disk drive, fully retract the disk mount until you hear a click.
  9. Toshiba Satellite A215 S4697 Optical Drive Replacement: Schritt 9, Bild 1 von 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: Schritt 9, Bild 2 von 3 Toshiba Satellite A215 S4697 Optical Drive Replacement: Schritt 9, Bild 3 von 3
    • Continue to pull the disk drive toward you until it is completely removed from the laptop's housing.
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 4-12, Maness Spring 2013 Mitglied von Cal Poly, Team 4-12, Maness Spring 2013
CPSU-MANESS-S13S4G12
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 21
Insgesamt: 4,374
