Was du brauchst
Turn off the computer.
Disconnect the charging cable from computer.
Flip the computer upside down.
Slide latches labeled #1 and #2, located outside the battery cover, away from each other.
Loosen 1 Phillips 4.2 mm size captive screw and lift cover off device to expose 2 RAM sticks.
In diesem Schritt verwendetes Werkzeug:Anti-Static Wrist Strap$7.95
Locate 2 metal pinchers on either side of the 1st RAM stick.
Use a finger from each hand to push the 2 pinchers simultaneously away from the stick of RAM and towards the exterior of the case.
The RAM stick will automatically rise up. Gently pull out the RAM stick with one hand.
Locate and remove 1 Phillips 4.2 mm size screw along right side of RAM container.
Push down metal rod until optical drive pops out from its container on the side of the device.
