Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
Turn off the computer.
Disconnect the charging cable from computer.
Flip the computer upside down.
Slide latches labeled #1 and #2, located outside the battery cover, away from each other.
Loosen 1 Phillips 4.2 mm size captive screw and lift cover off device to expose 2 RAM sticks.
Locate 2 metal pinchers on either side of the 1st RAM stick.
Use a finger from each hand to push the 2 pinchers simultaneously away from the stick of RAM and towards the exterior of the case.
The RAM stick will automatically rise up. Gently pull out the RAM stick with one hand.
