Zum Hauptinhalt wechseln
Toshiba Satellite A215-S7425 Screen Replacement
Was du brauchst
  1. Toshiba Satellite A215-S7425 Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off the computer.
    • Disconnect the charging cable from computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Toshiba Satellite A215-S7425 Screen Replacement: Schritt 2, Bild 1 von 1
    • Slide latches labeled #1 and #2, located outside the battery cover, away from each other.
    • Latch #1 will click over and stay while latch #2 will have to be held for battery to release.
  3. Toshiba Satellite A215-S7425 Screen Replacement: Schritt 3, Bild 1 von 1
    • Gently lift and pull the battery out of the device.
  4. Toshiba Satellite A215-S7425 Screen Replacement, Screen: Schritt 4, Bild 1 von 2 Toshiba Satellite A215-S7425 Screen Replacement, Screen: Schritt 4, Bild 2 von 2
    • Use tweezers to remove rubber screw covers on 4 corners of frame around screen.
  5. Toshiba Satellite A215-S7425 Screen Replacement: Schritt 5, Bild 1 von 1
    • Remove 4 Phillips 5.6 mm screws.
  6. Toshiba Satellite A215-S7425 Screen Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite A215-S7425 Screen Replacement: Schritt 6, Bild 2 von 2
    • Use flat side of spudger to pry the top and sides of the frame around screen.
  7. Toshiba Satellite A215-S7425 Screen Replacement: Schritt 7, Bild 1 von 2 Toshiba Satellite A215-S7425 Screen Replacement: Schritt 7, Bild 2 von 2
    • Turn device onto its screen side to access the bottom of hinge portion of the screen and push bottom piece of frame along device hinge until it loosens.
  8. Toshiba Satellite A215-S7425 Screen Replacement: Schritt 8, Bild 1 von 3 Toshiba Satellite A215-S7425 Screen Replacement: Schritt 8, Bild 2 von 3 Toshiba Satellite A215-S7425 Screen Replacement: Schritt 8, Bild 3 von 3
    • Return device to upright position and gently pull frame away from screen.
  9. Toshiba Satellite A215-S7425 Screen Replacement: Schritt 9, Bild 1 von 1
    • Remove 2 Phillips 5.6 mm screws from below screen.
  10. Toshiba Satellite A215-S7425 Screen Replacement: Schritt 10, Bild 1 von 2 Toshiba Satellite A215-S7425 Screen Replacement: Schritt 10, Bild 2 von 2
    • Unplug pink and white monitor cable from bottom of screen.
  11. Toshiba Satellite A215-S7425 Screen Replacement: Schritt 11, Bild 1 von 1
    • Remove 3 Phillips 3.2 mm screws from each side of the metal case around screen.
  12. Toshiba Satellite A215-S7425 Screen Replacement: Schritt 12, Bild 1 von 1
    • Pull the screen forward from the top out of the metal frame enough to see the back of the screen.
  13. Toshiba Satellite A215-S7425 Screen Replacement: Schritt 13, Bild 1 von 3 Toshiba Satellite A215-S7425 Screen Replacement: Schritt 13, Bild 2 von 3 Toshiba Satellite A215-S7425 Screen Replacement: Schritt 13, Bild 3 von 3
    • Hold the screen with one hand and gently remove the display cable from the back side of the screen.
    • The display cable is typically glued or taped to the back of the screen. Take care to carefully lift the tape and slowly pull cable.
    • To avoid damaging screen ribbon cable, use caution and be gentle. Do not yank or remove with force. Avoid bending the ribbon cable which can cause the wires inside it to snap and break.
Abschluss
Marianne
647 Reputation
6 Anleitungen geschrieben
Pasco Hernando, Team 5-2, Prince Fall 2014 Mitglied von Pasco Hernando, Team 5-2, Prince Fall 2014
PHSC-PRINCE-F14S5G2
10 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 13
Insgesamt: 435
