Zum Hauptinhalt wechseln
Toshiba Satellite A305-S6848 Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite A305-S6848 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Close laptop and turn it upside down.
  2. Toshiba Satellite A305-S6848 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Move the left locking hatch to the left.
    • Hold the right spring latch to the right.
  3. Toshiba Satellite A305-S6848 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the battery from the laptop.
  4. Toshiba Satellite A305-S6848 Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 1
    • The keyboard is held in by a locking strip between the screen and the keyboard.
  5. Toshiba Satellite A305-S6848 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Use the metal spudger to pry out the right portion of the locking piece just above the DEL key.
  6. Toshiba Satellite A305-S6848 Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Use your hand to take out locking strip from the right portion that was pried out.
  7. Toshiba Satellite A305-S6848 Keyboard Replacement: Schritt 7, Bild 1 von 2 Toshiba Satellite A305-S6848 Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Use the Phillip's #0 screwdriver to take out the two 5.8 mm Phillip's #0 screws from the top right and left corners of the keyboard.
  8. Toshiba Satellite A305-S6848 Keyboard Replacement: Schritt 8, Bild 1 von 2 Toshiba Satellite A305-S6848 Keyboard Replacement: Schritt 8, Bild 2 von 2
    • Lift the keyboard up slightly. Use caution as the keyboard ribbon cable is still attached below the keyboard.
    • Disconnect the keyboard by flipping the locking clip upwards.
Abschluss
Joshua E Hong
449 Reputation
4 Anleitungen geschrieben
Baylor, Team S8-G1, Johnson Fall 2017 Mitglied von Baylor, Team S8-G1, Johnson Fall 2017
BU-JOHNSON-F17S8G1
2 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 561
