Zum Hauptinhalt wechseln
Toshiba Satellite A305-S6848 LCD Screen Replacement
Was du brauchst
  1. Toshiba Satellite A305-S6848 LCD Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Close laptop and turn it upside down.
  2. Toshiba Satellite A305-S6848 LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Move the left locking hatch to the left.
    • Hold the right spring latch to the right.
  3. Toshiba Satellite A305-S6848 LCD Screen Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the battery from the laptop.
  4. Toshiba Satellite A305-S6848 LCD Screen Replacement, LCD Screen: Schritt 4, Bild 1 von 2 Toshiba Satellite A305-S6848 LCD Screen Replacement, LCD Screen: Schritt 4, Bild 2 von 2
    • Remove the 6 rubber tabs on the housing using the metal spudger.
  5. Toshiba Satellite A305-S6848 LCD Screen Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite A305-S6848 LCD Screen Replacement: Schritt 5, Bild 2 von 2
    • Remove the six 5.8 mm screws using the Phillip's #0 screwdriver.
  6. Toshiba Satellite A305-S6848 LCD Screen Replacement: Schritt 6, Bild 1 von 1
    • Pry out plastic housing on all sides.
  7. Toshiba Satellite A305-S6848 LCD Screen Replacement: Schritt 7, Bild 1 von 2 Toshiba Satellite A305-S6848 LCD Screen Replacement: Schritt 7, Bild 2 von 2
    • Pry out the bottom left and right locking pieces of the plastic housing with the metal spudger.
  8. Toshiba Satellite A305-S6848 LCD Screen Replacement: Schritt 8, Bild 1 von 2 Toshiba Satellite A305-S6848 LCD Screen Replacement: Schritt 8, Bild 2 von 2
    • Remove the four 5.8 mm screws using the Phillip's #0 screwdriver.
  9. Toshiba Satellite A305-S6848 LCD Screen Replacement: Schritt 9, Bild 1 von 1
    • Remove the eight 6.5 mm screws on the left and right sides of the screen using the Phillip's #0 screwdriver.
  10. Toshiba Satellite A305-S6848 LCD Screen Replacement: Schritt 10, Bild 1 von 2 Toshiba Satellite A305-S6848 LCD Screen Replacement: Schritt 10, Bild 2 von 2
    • Pull the screen down.
    • Pull off tape and take our video connector.
  11. Toshiba Satellite A305-S6848 LCD Screen Replacement: Schritt 11, Bild 1 von 1
    • Remove cold cathode fluorescent light bulb connector.
Abschluss
Joshua E Hong
449 Reputation
4 Anleitungen geschrieben
Baylor, Team S8-G1, Johnson Fall 2017 Mitglied von Baylor, Team S8-G1, Johnson Fall 2017
BU-JOHNSON-F17S8G1
2 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 509
