Einleitung
This guide provides step by step instructions on how to replace the internal fan.
Was du brauchst
Flip the laptop over so the bottom is facing up.
Slide each of the three tabs on the bottom half of the assembly into the unlocked position.
Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
Remove the twelve 8mm button head Phillips #00 B8 screws.
Remove the two 14 mm button head Phillips #00 B14 screws.
Remove the two 10 mm Phillips #00 battery compartment screws.
Remove the two 8 mm Phillips #00 screws.
Remove the seven 4mm flat Phillips #00 screws.
Remove the seven 20mm button head Phillips #00 screws.
Remove the three 2 mm Phillips #00 screws that secure the fan to the motherboard.
Remove the small plug connecting the fan power cable to the motherboard.
Carefully lift the fan out of the computer.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
