Einleitung
This guide provides step by step instructions of how to replace a faulty keyboard.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Flip the laptop over so the bottom is facing up.
    • Flip the laptop over so the bottom is facing up.
    • Slide each of the three tabs on the bottom half of the assembly into the unlocked position.
  2. Gently lift the battery out of the computer.
    • Gently lift the battery out of the computer.
  3. Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
    • Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
  4. Remove the WIFI module cover. It will pull right off.
    • Remove the WIFI module cover. It will pull right off.
  5. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  6. Unplug the white and black wires from the WiFi module. Unplug the white and black wires from the WiFi module.
    • Unplug the white and black wires from the WiFi module.
  7. Remove the twelve 8mm button head Phillips #00 B8 screws.
    • Remove the twelve 8mm button head Phillips #00 B8 screws.
    • Remove the two 14 mm button head Phillips #00 B14 screws.
    • Remove the two 10 mm Phillips #00 battery compartment screws.
    • Remove the two 8 mm Phillips #00 screws.
  8. Remove the seven 4mm flat Phillips #00 screws.
    • Remove the seven 4mm flat Phillips #00 screws.
    • Remove the seven 20mm button head Phillips #00 screws.
  9. Use the plastic opening tool to pry the two halves apart.
    • Use the plastic opening tool to pry the two halves apart.
  10. Using a screw driver for assistance, pop open the plastic cover and snap it off of the hinges. Repeat on the opposite side.
    • Using a screw driver for assistance, pop open the plastic cover and snap it off of the hinges. Repeat on the opposite side.
  11. Remove the two 3mm Phillips #00 screws.
    • Remove the two 3mm Phillips #00 screws.
  12. Slide keyboard out and away from the upper assembly.
    • Slide keyboard out and away from the upper assembly.
Abschluss
Aditya Varkhedi
104 Reputation
1 Anleitung geschrieben
Cal Poly, Team 14-8, Forte Fall 2013 Mitglied von Cal Poly, Team 14-8, Forte Fall 2013
CPSU-FORTE-F13S14G8
4 Mitglieder
5 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 531
