Zum Hauptinhalt wechseln
Toshiba Satellite A65-S126 Speaker Replacement
Was du brauchst
  1. Toshiba Satellite A65-S126 Speaker Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop over so the bottom is facing up.
    • Slide each of the three tabs on the bottom half of the assembly into the unlocked position.
  2. Toshiba Satellite A65-S126 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Gently lift the battery out of the computer.
  3. Toshiba Satellite A65-S126 Speaker Replacement, Upper Assembly: Schritt 3, Bild 1 von 1
    • Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
  4. Toshiba Satellite A65-S126 Speaker Replacement: Schritt 4, Bild 1 von 1
    • Remove the WIFI module cover. It will pull right off.
  5. Toshiba Satellite A65-S126 Speaker Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite A65-S126 Speaker Replacement: Schritt 5, Bild 2 von 2
    • Unplug the white and black wires from the WiFi module.
  6. Toshiba Satellite A65-S126 Speaker Replacement: Schritt 6, Bild 1 von 1
    • Remove the twelve 8mm button head Phillips #00 B8 screws.
    • Remove the two 14 mm button head Phillips #00 B14 screws.
    • Remove the two 10 mm Phillips #00 battery compartment screws.
    • Remove the two 8 mm Phillips #00 screws.
  7. Toshiba Satellite A65-S126 Speaker Replacement: Schritt 7, Bild 1 von 1
    • Remove the seven 4mm flat Phillips #00 screws.
    • Remove the seven 20mm button head Phillips #00 screws.
  8. Toshiba Satellite A65-S126 Speaker Replacement: Schritt 8, Bild 1 von 1
    • Use the plastic opening tool to pry the two halves apart.
  9. Toshiba Satellite A65-S126 Speaker Replacement, Speaker: Schritt 9, Bild 1 von 2 Toshiba Satellite A65-S126 Speaker Replacement, Speaker: Schritt 9, Bild 2 von 2
    • Locate the plug for the speaker wires on the bottom of the laptop.
  10. Toshiba Satellite A65-S126 Speaker Replacement: Schritt 10, Bild 1 von 1
    • Unplug the speaker wire connector.
  11. Toshiba Satellite A65-S126 Speaker Replacement: Schritt 11, Bild 1 von 1
    • Remove the speakers by sliding them straight up. They should slide out with ease.
Abschluss
Cole Uhland
216 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 14-8, Forte Fall 2013 Mitglied von Cal Poly, Team 14-8, Forte Fall 2013
CPSU-FORTE-F13S14G8
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 525
