Zum Hauptinhalt wechseln
Toshiba Satellite A660-ST3NX2X Screen Replacement
Was du brauchst
  1. Toshiba Satellite A660-ST3NX2X Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Unplug all cables and other devices from the computer before starting this replacement.
    • Turn the computer over, so the screen is facing down and the battery is positioned in front of you.
  2. Toshiba Satellite A660-ST3NX2X Screen Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite A660-ST3NX2X Screen Replacement: Schritt 2, Bild 2 von 2
    • Locate the two sliding tabs on either side of the battery.
    • Using both hands, place one finger on each tab and slide them to the sides and away from each other.
  3. Toshiba Satellite A660-ST3NX2X Screen Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite A660-ST3NX2X Screen Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite A660-ST3NX2X Screen Replacement: Schritt 3, Bild 3 von 3
    • Pull the battery out, keeping the tabs pushed to the side.
    • The right tab on this laptop stayed pushed to the right without needing to be held in place.
  4. Toshiba Satellite A660-ST3NX2X Screen Replacement, Screen: Schritt 4, Bild 1 von 2 Toshiba Satellite A660-ST3NX2X Screen Replacement, Screen: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Unplug all devices and power down the computer completely.
    • Peel back all four circular stickers that are located at each corner of the computer frame.
    • A pair of fine point tweezers was used to complete this.
  5. Toshiba Satellite A660-ST3NX2X Screen Replacement: Schritt 5, Bild 1 von 1
    • Unscrew all four 5mm screws located underneath the stickers in each corner of the computer frame.
    • The computer frame should become more loose after the screws are removed.
  6. Toshiba Satellite A660-ST3NX2X Screen Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite A660-ST3NX2X Screen Replacement: Schritt 6, Bild 2 von 2
    • Pry the frame of the screen away from the computer.
    • A prying tool was used by inserting it in the crack between the frame and the screen and running it along the edges of the frame.
  7. Toshiba Satellite A660-ST3NX2X Screen Replacement: Schritt 7, Bild 1 von 2 Toshiba Satellite A660-ST3NX2X Screen Replacement: Schritt 7, Bild 2 von 2
    • Unscrew the three black 4mm JIS screws on each side of the metal frame that is still attached to the side of the screen.
    • Only two screws are shown in the image.
    • The metal frame will completely separate from the computer screen.
  8. Toshiba Satellite A660-ST3NX2X Screen Replacement: Schritt 8, Bild 1 von 3 Toshiba Satellite A660-ST3NX2X Screen Replacement: Schritt 8, Bild 2 von 3 Toshiba Satellite A660-ST3NX2X Screen Replacement: Schritt 8, Bild 3 von 3
    • Position the screen in a way that the aluminum backing is exposed.
    • Peel off the metal-like attachment from the back of the screen.
Abschluss
Megan Murrell
322 Reputation
3 Anleitungen geschrieben
Texas Tech, Team S8-G1, Bennett Spring 2017 Mitglied von Texas Tech, Team S8-G1, Bennett Spring 2017
TTU-BENNETT-S17S8G1
4 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 504
