Einleitung
If your battery will not retain charge when your computer is unplugged from the adaptor, your battery may be faulty, and you may need to replace it. Replacing your Toshiba Satellite A665-S5170 battery does not require any tools and takes relatively little time.
Was du brauchst
Turn the computer upside-down so that the bottom of the laptop is facing up.
Using the tip of your finger, slide the right clasp of the battery panel horizontally to the right until it locks into place.
Slide the left clasp of the battery panel horizontally to the left, and hold it in place.
While continuing to hold the left clasp of the battery panel in place, slide out the old battery by pulling it towards you.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
