Einleitung
Use this guide to replace or install the disc drive in your Toshiba laptop.
Was du brauchst
Flip the laptop over and orient it such that the battery faces towards you and the front faces away from you as shown in the diagram.
Unlock the battery by sliding the tab shown to the right
Slide the tab shown to the left and remain holding it.
Place your thumb on the grips of the battery as shown.
While holding onto the grips, pull the battery towards you and away from the laptop.
Flip the laptop over and orient it so that the battery faces away from you.
Remove the 5mm Phillips #0 screw on the bottom case.
Insert the plastic opening tool into the gap between the disk drive and the laptop and pop out the disk drive.
Slid the disc drive out of its slot on the left side of the computer. It should slide out easily.
