Zum Hauptinhalt wechseln
Toshiba Satellite C50D-A RAM Replacement
Was du brauchst
  1. Toshiba Satellite C50D-A RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Click button 1 to the unlocked position.
    • This button will have a 1 by it.
  2. Toshiba Satellite C50D-A RAM Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite C50D-A RAM Replacement: Schritt 2, Bild 2 von 2
    • Push and hold button 2 to the left.
    • As you push button 2 to the left position, simultaneously lift up the battery pack.
    • This button will have a 2 by it.
  3. Toshiba Satellite C50D-A RAM Replacement, Lower Case: Schritt 3, Bild 1 von 2 Toshiba Satellite C50D-A RAM Replacement, Lower Case: Schritt 3, Bild 2 von 2
    • Using the Phillips #1 screwdriver, remove the eleven 2.5mm screws.
  4. Toshiba Satellite C50D-A RAM Replacement: Schritt 4, Bild 1 von 1
    • Remove the one 2.5mm Phillips #1 middle plate screw.
  5. Toshiba Satellite C50D-A RAM Replacement: Schritt 5, Bild 1 von 1
    • Lift up the middle vent panel.
    • Set the panel to the side.
  6. Toshiba Satellite C50D-A RAM Replacement: Schritt 6, Bild 1 von 3 Toshiba Satellite C50D-A RAM Replacement: Schritt 6, Bild 2 von 3 Toshiba Satellite C50D-A RAM Replacement: Schritt 6, Bild 3 von 3
    • Using the plastic opening tool, remove the outer panel and set to the side.
    • Be careful not to break the back of the computer.
  7. Toshiba Satellite C50D-A RAM Replacement, RAM: Schritt 7, Bild 1 von 1
    • Using your fingers, unclip the two side clips.
  8. Toshiba Satellite C50D-A RAM Replacement: Schritt 8, Bild 1 von 2 Toshiba Satellite C50D-A RAM Replacement: Schritt 8, Bild 2 von 2
    • The RAM should now be at a 30 degree angle.
    • Using your fingers, unclip the top two clips.
    • The RAM should just pop out. You can remove it with your fingers.
    • This will apply to either top or bottom RAM.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 18
Insgesamt: 788
