Einleitung
This guide will walk you through the process of replacing the charging port jack. Replacing the charging jack port is important as it allows the computer to regain a state where it could be utilized again.
To do so, one must remove the back cover. The back cover is attached by not only screws, but also plastic clips.
Was du brauchst
Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
Place laptop with the bottom of it facing up.
Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
Place the laptop with the bottom facing up.
Using the Phillips #1 screwdriver, remove the 8mm screw that is holding the hard drive in place.
Use your finger to lift the hard drive up.
Pull out the hard drive to the right.
Unscrew all 15 screws that attach the back cover to the laptop.
Carefully pry the back cover off the laptop using the prying tools, starting from the hard drive side.
Locate the charging jack. Then carefully pull straight up.
Unplug the connector by pulling it towards the charging port side of the case, then carefully guide the wires away from the case.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
