Einleitung
This guide will show you how to remove or replace the hard drive of the Toshiba Satellite C55-A5286 laptop. A Phillips screwdriver of head size PH0 is required for this guide.
Was du brauchst
Carefully hold the sides of the hard drive with the rubber and pull the hard drive out. It should remove fairly easily.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
The hard drive is ‘encased’ in a foil-looking, very flexible ‘enclosure’.
On the screw-side (near the label), each corner of the foil enclosure has a rubber black stuffed between the drive and the laptop - these blocks are connected to the enclosure via a rubber ‘string’. If you pull those nubs straight up, you can pull on them towards the label to disengage the drive from its SATA interface.
