Einleitung
This guide will show you how to disassemble the Toshiba Satellite C55-A5302 to remove and replace the ODD.
Was du brauchst
Power down the laptop and remove all power cords. After this is done, turn the laptop over.
Use the Phillips #1 screwdriver to unscrew the thirteen screws on the back of your device.
Using the Phillips #1 screwdriver, remove the two screws holding the hard drive in place.
Remove the three screws using the Phillips #1 screwdriver.
Insert you fingers into the rubber ends and gently pull the hard drive out of the device.
Use the Phillips #1 screwdriver to remove the two screws under the hard drive.
Use a metal spudger and run it along the edges of the computer to take off the plastic back cover. (Starting near a port usually allows more space for the spudger to be inserted)
Grab hold of the optical drive and elevate it slightly and remove it from the computer.
