Zum Hauptinhalt wechseln
Toshiba Satellite C55-A5302 Screen Replacement
Was du brauchst
  1. Toshiba Satellite C55-A5302 Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power down the laptop and remove all power cords. After this is done, turn the laptop over.
  2. Toshiba Satellite C55-A5302 Screen Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery latches outwards away from the center of the device.
    • The right latch will slide to the right, and left latch to the left.
  3. Toshiba Satellite C55-A5302 Screen Replacement: Schritt 3, Bild 1 von 1
    • Lift and remove the battery from the device.
  4. Toshiba Satellite C55-A5302 Screen Replacement, Screen: Schritt 4, Bild 1 von 1
    • Use tweezers to remove the screw covers in the lower corners of the screen.
  5. Toshiba Satellite C55-A5302 Screen Replacement: Schritt 5, Bild 1 von 1
    • Use the Phillips #1 screwdriver to unscrew the two screws in the lower corners of the screen.
  6. Toshiba Satellite C55-A5302 Screen Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite C55-A5302 Screen Replacement: Schritt 6, Bild 2 von 2
    • Start popping off the cover all the way around the screen until it comes off.
  7. Toshiba Satellite C55-A5302 Screen Replacement: Schritt 7, Bild 1 von 2 Toshiba Satellite C55-A5302 Screen Replacement: Schritt 7, Bild 2 von 2
    • Remove the two screws in the top corners with a Phillips #1 screwdriver. The screen will pop forward after removing the two screws.
    • Using the same Phillips #1 screwdriver, remove the three screws on the side of screen frame.
  8. Toshiba Satellite C55-A5302 Screen Replacement: Schritt 8, Bild 1 von 2 Toshiba Satellite C55-A5302 Screen Replacement: Schritt 8, Bild 2 von 2
    • On the back of screen, lift up the plastic film and screen connector. Pop out the connector, and gently remove the screen.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 27
Insgesamt: 658
